dxb2013
Good evening,
I am trying to fit a PIR indoors in a walk in wardrobe. I have attached some pictures below. A couple of the PIR rear and the wiring diagram included in the box, and another two...one shows the wall switch with one live wire and the other to the light I assume. I have also taken a picture of the wiring in the roof that is attached to the current light. One is black, yellow and the earth....which is confusing. The other side of the chocolate block goes to the light in the ceiling.
Could someone help me figure out what wires go where. Do I simply cut the three wires (black, yellow and earth in the ceiling) and put them into the PIR and then back out to where they are going? Ideally I want the wall switch to override the PIR but not interfere with it beyond the occasional switching on and off override. If its easier then maybe I'll forget the wall switch and just use the PIR.
Help!
Help!
