Fitting ABS pipe plumbing advice | on ElectriciansForums
Discuss Fitting ABS pipe plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Fitting ABS pipe Anyone worked with this plastic pressurised pipe much? This week was my first and i thought after my years of experience that these stressful days were mostly behind me...alas they are not.
Ordered up the stuff in preparation for the job, informed the entire building that the water would be off for 24hrs to allow the glue to cure and then proceeded to drain down and cut out the old stuff yesterday, only to find that the stuff that was in was imperial sized Durapipe, this meant i was all over the city trying to find someone that stocked some couplings off the shelf. Eventually found somewhere, thank god, and then went back to do the job. Water is being turned back on today at half 5, lovely little end to a Friday.... haha, you live and learn i suppose.
Fitting ABS pipe to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Fitting ABS pipe plumbing advice in the Plumbers Forums area at ElectriciansForums.net
T
What plumbing tape is recommended for a copper waste water pipe Hi there, We have a leaking waste water pipe which our washing machine, boiler and...
Tellie
T
L
What manufacturer makes the best quality fittings for multilayer pipes? What manufacturer makes the best quality fittings for multilayer pipes...
LordWest
L
