View the thread, titled "Fitting an air admittance valve to 32mm push fit elbow problem" which is posted in Plumbers Forums on Electricians Forums.
In the photo there is a grey 32mm push fit elbow between the sink trap and down pipe. I want to replace the elbow with a "male" push fit tee attached to an air admittance valve to stop gurgling noises.
I can't find a tee fitting that description, can anybody offer a solution as you can see space is limited
Continue reading...
Reply to the thread, titled "Fitting an air admittance valve to 32mm push fit elbow problem" which is posted in Plumbers Forums on Electricians Forums.
ShowerSmellProblems
Plumbers Forums
elmocambo,
