Fitting and bulb full of water, light still working! | on ElectriciansForums
Discuss Fitting and bulb full of water, light still working! in the UK Electrical Forum area at ElectriciansForums.net
DNS1
Had a call from a family member today saything they'd had a flood and the elecs had tripped.
Dropped by and reset the RCD. It held, so I assumed whatever had got wet had dried out.
Started pulling a few boards up and everything seemed ok, damp plaster but nothing too bad...
Went into the downstairs loo to see if there was any sign of damp in the light fitting. I removed the globe over the bulb and got VERY wet! Was full to the brim with water, but the light was working fine!
Immediately isolated and started investigating, found the actual bulb (old GLS) itself had water in it...
Just goes to show how even in this day and age of highly reliable MCBs and RCD protection on everything, electrical kit can still end up submerged and not trip out!
I wonder if I'd left it alone the water would have boiled in my light fitting!
Wonder how long it would have been before the steam and condensation caused the RCD to go...
Reminds me of something the lads on my Student Union technical committee used to do...
Get a figure-8 lead, replace the fuse with a nail and stick the end in a glass of salt water (I think!). Hold the MCB on and watch as it "danced" around on the table...
They wanted to try it with a 125A 3-phase cable and a dustbin but someone thought better of it...
Dicking about and bodging is one of the great learning processes!
Sadly health and safety took over at our student union, no opportunity for people to learn like we used to.
well a month ago I was called out to a bathroom 28 watt 2D fitting so I went to rotate the cover off only to find whoever put it on last only turned it a bit so expecting to rotate it round I just touched it and yep the whole lot came down all over me . Went to return the keys and the girls in the letting agents thought I had peed myself lol not a good day
And why they only use deionized water on high pressure cleaning of HV stings and insulators on overhead pylons!! lol!!
Dont fancy that job!!!!
Thats a job for the apprentice.
"Is it definitely the deionized stuff boss?" :goofy:
"Yeh for sure, just blast it" :uhoh2:
"I cant hear you boss, why are you stood so far away?" :dizzy2:
"Im just fetching a sky hook, just spray it will you!" :builder:
We used it for the power cables for furnaces. Each flexable could have up to 4000A flowing through it. Water pumped down each cable. If the return water temp went above the low alarm limit, it was panic time. High limit, get the fire hoses out!
Reply to Fitting and bulb full of water, light still working! in the UK Electrical Forum area at ElectriciansForums.net
My guess is an earth to N fault in the damaged light fitting. This will become a problem when other devices draw large currents.
