Fitting led lIght bar - Large Voltage Drop | on ElectriciansForums
Discuss Fitting led lIght bar - Large Voltage Drop in the Auto Electrician Forum area at ElectriciansForums.net
Lexlee
Huntingdon
Hi, posting for a friend,
Whilst fitting a LED Light bar ( believed to be 120w) to a Landrover Defender (1995) he tapped into the signal wire of a relay that supplies his roof spot lights and used that as his signal for the light bar relay..
He has used the horns earth for the relay and also connected the earth from the Light bar to the same point, as it's redundant (air horn fitted)
His problem is that the bar initially lit up on main beam, then when to try the flash ... Nothing. The relay for the light bar can be heard clicking on and off, and when the bar is disconnected has correct voltage at the light bar connection point. when the bar is reconnected the voltage drops to 3v at the same point. Thinking the Light bar was now defective he then tested it on another battery and it works fine..
As there's not a great deal there could it be
1 Problem with signal to light bar relay
2 the earth point for relay being same as ligh bar
3 the relay itself
The wire he has used is 17 rated at 17 amp
Hopefully I've explained well enough ... If anymore info is required only to glad to supply it . Friends can be a pain as I hate typing , any ideas on subject would be greatly appreciated.. Thank you
It could be volt drop on the cables used, which can be fixed by using a bigger cable. If the bake is rated at 17A I guess it's 1.5mm thin wall automotive cable.
When we fitted a pair of 50W spots to the back of our van we had to use 4mm to overcome the voltage drop in the cable.
Also you might well have corrosion in the earth path, whereabouts on the vehicle have you connected it to earth?
Hi,
Sean_ork... Have run a cable to Earth on battery.... No change
Connected earth back up then ran pos from light to battery it lights up. So I assume the earth is ok?
Davesparks ...... The cable (just used micrometer First time in years) is 3.5 mm and is rated at 17amp says he got it from H..fords. The earth for the relay he's has connected that to the original earth for the vehicle horn (air horn fitted drivers side) and also connected the earth from the light bar to the same point as the relay earth ( original vehicle horn)
So the relay is switched by the spotlights, but what supplies the positive 12v feed to the relay (ie, pin 87 or 30, doesn't matter which way round), which it then outputs to the LED bar?
You mean the outside diameter of the wire including the insulation? The Halfords 17A wire works out at 1.85mm².
A direct feed from the betters and it works,,
There is an extra 6 holder fuse box on bulkhead under the bonnet supplied by battery as vehicle is ex utilities ( elec or water board or similar) the feed for spots and light bar are from there. The vehicle is outside would photos help, the wiring isn't pretty as just trying to get it to work then guess he'll idly it up.
I said before on initial operation the light bar worked it was only when the flash was used and now the spots work as before but no light bar.
Do you mean take the signal wire and connect it to the wire that supplies the bar , basically removing the relay from the equation?
No, there must be a feed for the switching part of the relay which then puts the feed out to the bar when the relay is activated. Link these together but disconnect the battery first.
Reply to Fitting led lIght bar - Large Voltage Drop in the Auto Electrician Forum area at ElectriciansForums.net
Good to know. Thanks again!
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
