B
blueschill
I have to fit a fiberglass molded hydro/massage shower that has molded base, backing, top and sides, all sealed.
underneath the base is a junction box and a water tank/heater ( lots of wiring ) and on the back of the enclosure are lots of pipe going to various nozzles and cables for lights and thermostats etc...
Coming from the junction box is 6mm flex cable that is around a mtr and a half.
The bathroom it is being fitted in is being renovated and the unit will be fitted and sealed to the wall leaving a cavity behind it for wiring, pipes molding etc..
Problem is there is no fitting instructions and I cannot identify the unit!
I am aware that The space under the bath tub or shower basin is considered to be zone 1. However, if the space under the bath or shower basin is only accessible with a tool, it is considered to be outside the zones.
so this is the question as it will have an inaccessible area ( without using tools ) behind the molded unit, doesn't it count as being outside the zones? I am not sure as it has lots of water pipes around the area and I am a bit dubious.
If it is considered outside the zones can I run from a pull cord switch a buried supply cable down the wall into a major surface mounted junction box waterproof of course like a ip68 (just in-case of a pressurized leak) and hook the showers original flex up to the junction box for ease of installment and maintenance to the shower unit ( pulling it out, to get in behind it ).
If it is however considered to be a zone should i just run a buried cable down near the bottom of the wall and directly wire it into the shower unit?
Please bear in mind I have never fitted anything like this before
Cheers guys
Cheers guys
