Fitting Sockets. | Page 3 | on ElectriciansForums
Discuss Fitting Sockets. in the UK Electrical Forum area at ElectriciansForums.net
iverpool
I guess you could file this under hints and tips.
When you're installing a socket the worst part, for me at least, is pushing it into place
and keeping it there while you tighten the screws. That means bending the cables,
however many there are. It can be quite a feat of strength and and a bit nerve racking.
I have actually cracked a few new sockets in the past and had to replace again.
I use pointed nose pliars to bend them but it's still a pain and a struggle.
What do you guys do? Is there a special pair of pliars available for this purpose?
Bending the cables? I did see something on the net a while ago but can't find it now.
Should have bought one when I saw it I suppose.
Any suggestions?
Cheers
No no no.... you use the smallest screwdriver you’ve got to screw back plates.... ones that dig into the slot when tight and leave it all chewed up.....
If you’re really good, you can mis-thread the screw, so you really have to force it.... it’ll never come out after that.
I personally prefer to use screws that are too long, and force them to bend over at the end when they hit the metal back box....
No No NO, your doing it all wrong...
2 inch #8 wood screw for face plates , that sucker will be nice and tight
Had to replace a single socket in a tiled kitchen where they'd done this :angry:
Lugs both bent and holes way to big for rethreading - No way to replace the back box without removing tiles.
Used one of these things - Fix a broken screw thread in your metal back box. Raise, tilt or lower a socket faceplate - https://backboxsaver.com - which did work, though only after a lot of fiddling and swearing and it was still only being held firm properly by one of the screws....
We’re all laughing at this, but really? You screw back until it’s tight. A quarter turn to get the slot horizontal or vertical is the difference between the plate moving or not.
I wouldn’t be surprised if a customer found a loose socket when using it, and gave the screw a quarter or so turn to tighten it, and calling you all sorts for leaving it loose.
using any mechanical means to screw back a faceplate screw is a recipe for cracking the plastic.
A bodge I've used, on a couple of occasions, to deal with a stripped or missing lug, is to drill a 6mm hole in the back of the box, directly behind the lug, then to use a masonry drill to drill out the mortar for a red or yellow plug, then to fit the plate with a very long #6 woodscrew.
But what a price! ÂŁ5.99 for one ?
Yep - expensive for what they are (presumably because they are made in low volume). And not perfect by any means - could only get one to stay in place in a single socket, though probably would more successful in a double socket where there is more space to get a finger in at one end while the other is connected....
Worth the cost for that job to avoid the hassle of getting a new back box in there though!
Reply to Fitting Sockets. in the UK Electrical Forum area at ElectriciansForums.net
