Fitting Sockets. | Page 4 | on ElectriciansForums
Discuss Fitting Sockets. in the UK Electrical Forum area at ElectriciansForums.net
iverpool
I guess you could file this under hints and tips.
When you're installing a socket the worst part, for me at least, is pushing it into place
and keeping it there while you tighten the screws. That means bending the cables,
however many there are. It can be quite a feat of strength and and a bit nerve racking.
I have actually cracked a few new sockets in the past and had to replace again.
I use pointed nose pliars to bend them but it's still a pain and a struggle.
What do you guys do? Is there a special pair of pliars available for this purpose?
Bending the cables? I did see something on the net a while ago but can't find it now.
Should have bought one when I saw it I suppose.
Any suggestions?
Cheers
They look strangely like the captive screw threads you can pick up for pennies to put onto car parts to hold panels etc, but without insulation? bit of heat shrink would cure that.
They do work, but aren't ideal.
They fit to the existing lug either with the little bit of sleeving, which isn't really strong enough to hold it in place while getting the screw lined up - at least not once your first attempt fails... or tiny sticky pads which don't stick to anything and are useless....
I guess a 3.5mm nut would effectively do the same thing if you could hold it behind the lug with a finger while getting the screw in - with a single box that's hard to do on both sides...
Spire clips. Yes, they are pretty much the same but obviously they have a 3.5 thread rather than a hole for a self tapper.
A bodge I've used, on a couple of occasions, to deal with a stripped or missing lug, is to drill a 6mm hole in the back of the box, directly behind the lug, then to use a masonry drill to drill out the mortar for a red or yellow plug, then to fit the plate with a very long #6 woodscrew.
Similar to this idea, but I've found a long 3.5mm socket screw will go nicely into a red plug.
i've used the pin extensions in the same way, into a red rawlplug, lined up with where the damaged lug was, then fitted a normal 3,5mm.
Reply to Fitting Sockets. in the UK Electrical Forum area at ElectriciansForums.net
