C
Conmeister
Howdo guys
Probably a daft question but its better than not asking. Just seeking clarity regards installing an accessible dp switch for a fridge and freezer. I've looked at Section 537 in regs and i'm still a bit confused. My understanding is that you need to have an isolation switch so you can turn off the freezer if you need to pull it out. This seems a bit OTT when you can just switch the circuit off for a couple of minutes. Is it essential to have this switch (would have to be at counter level)?
Thanks in advance
Conor
Thanks in advance
Conor
