Fixing a TWO Hub HIVE system (in a single house) | on ElectriciansForums
Discuss Fixing a TWO Hub HIVE system (in a single house) in the Central Heating Systems area at ElectriciansForums.net
Kettering
Over the course of getting the full house replumbed, a combination of our sparky and plumber have fitted a hive installation. The installation consists of two hubs, one which controls hot water and downstairs heating, the second controls the upstairs heating (over two floors). Each hub has its own receiver and own thermostat. All seems to work in terms of the thermostats controlling their individual receivers and in tern heating/water, but whilst I have registered one hub on the app (I have subsequently found out you can't register two) it won't find the thermostat connected to it. Also, whilst one of the receivers shows a solid green light, the other had shown a flashing green light since install (2 months ago).
Whilst trying to fix this I have found out that, in fact, the installation is wrong and have been told that I should have been fitted with one hub only and two thermostats in a multizone system. Having had a fairly long call with Hive today, they implied they could fix this over the phone by turning off one hub and connecting two thermostats to this.
I wanted an opinion as to whether this was possible or whether there was a potential hardwiring issue in terms of pumps/receivers/controllers etc that would prevent such an easy fix. I would have thought each hub would be wired to a separate pump and if I turn one off I will lose control of that pump? Ultimately I don't want to turn things off and then realise that I can't get the heating or water back on. If it helps I have an image of the plant room with the hubs and pumps but I can't work out how to attach?
Apologies in advance if any of this seems stupid!
Thanks in advance,
Simon
[ElectriciansForums.net] Fixing a TWO Hub HIVE system (in a single house)
You can only register one hub.
But you can make it a multi zone. So you would have one 2 channel receiver for heating and hot water and a thermostat. And a seperate single channel receiver for your other heating zone and a thermostat.
And multi zone only works with hives newer hubs
Thanks,
So I can just turn one of the hubs off in the plant room? How do I make the remaining one a multi-zone? And the remaining hub will definitely be able to control both zones, it won’t be hard wired to only control one?
Thanks again
Simon
Thanks,
Generally speaking the Hubs are the devices that plug into the router, the devices in the basement look like receivers to me.
The receivers pick up the signals from the stats but these need to registered to the Hub /gateway (the box thats plugged into your router),
Ive never used Hive but it should be pretty simple, your just have to log into it via a web browser its a bit like when you configure your router at home if you have ever done that.
Once setup you should be able to open the app and see both devices.
The hub it's what's plugged in to your broardband router.
And you can only have one.
Like hive said to you on the phone it can be done.
Makes sure the hub you have registered to your hive app is the one plugged in. Call hive back and they will talk you through setting it up. It will just be a case of resetting the thermostat that's not linked and syncing both your receivers to the one hub, so it becomes a multi zone
And if all the wiring is correct your good to go.
Ah that makes a bit more sense. If that is the case then in theory it could be sorted in setup with current install. Thanks.
Understood. That does make sense. Thanks!
Reply to Fixing a TWO Hub HIVE system (in a single house) in the Central Heating Systems area at ElectriciansForums.net
R
Hive thermostat multizone help Can anyone help me. I have just moved house and we have a boiler with a separate hot water tank and then 2...
Rick1980
R
Certainly is!! And another thing .......... On the old Hive receiver the relay common is a separate terminal, whereas on the new Hive presumably...
