N
Noob2013
Hi all,
A friend of mine has built a conservatory and has used surface mini trunking to contain the t&e for the lights, as the pvc blends in with the pvc panels of the conservatory.
I'm due to connect up the lights and wanted to know the best way and be prepared before u arrive.
I haven't seen the lights yet but im assuming they will be some sort of chrome fitting.
If so, then the mini trunking would end up butting up against the chrome base with no cable entry.
Is there some soft of box you can fix to the ceiling for the trunking to go into and then the light fix to the box? Maybe a bit like a pvc trunking box without the conduit entries.
