Discuss Fixing to Stone Roofs in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Could be worth trying an in-roof system. Sounds silly but them roofs are a nightmare.
Think you will find there are 3 slates covering each bit of the roof. Just like a normal slate roof, removing just one slate involves removing a good chunk of the roof. Also the slates will be deceptively long at least 2.5 times as long as the visual bit meaning any normal type anchor will need to be really long making it less stable.
I've used a ubbink solution before (see Pics) adds about a day or two to a 4.0kw install but its a better job and looks good too. You could do with a friendly roofer though to strip roof then allow you install base structure. he can then re-roof whist you install inverters + cabling e.t.c. Probably will only add half day to your labour then.
View attachment 7058View attachment 7059View attachment 7060
I'm a builder and roofer and have to say this looks like just the solution. Can't believe they didn't know about it!
Reply to Fixing to Stone Roofs in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
