Fixing wiring above suspended ceiling | on ElectriciansForums
Discuss Fixing wiring above suspended ceiling in the UK Electrical Forum area at ElectriciansForums.net
Stirling
Hi all
regarding securing cables above suspended ceiling. Is there anything against the regs from tie wrapping down a threaded rod to a light fitting. To keep it off the ceiling. This is run in FP200 so has earthed shield inside ?
Thanks for the replies, no support systems in the ceiling only have HVAC support systems, so was planning on running just using this system as it’s close to where the light will be getting installed and tie wrapping down the threaded rod with metal ties. Just didn’t know if this would be a good idea or not ?
It can be as simple as fixing metal strap banding to the upper ceiling.
this , some all round band simply screwed and plugged to the concrete ceiling...
far better than plastic cable ties to the ceiling grid support rods
Reply to Fixing wiring above suspended ceiling in the UK Electrical Forum area at ElectriciansForums.net
It isn't just about premature collapse that is more dealing with the method of support. Ignoring this, cables should be correctly supported to...
Brilliant thank you so much for your help 😊 x
