Flashing dimmer LEDs, what's the reason? | on ElectriciansForums
Discuss Flashing dimmer LEDs, what's the reason? in the UK Electrical Forum area at ElectriciansForums.net
gijno
london
Hi, I've installed two dimmer 60w Led bulbs, one in the bedroom and the other one in the dining room.
The first one is controlled by a 400w 2 Gangs 2 Way Dimmer BT (this one British General 2-Gang 2-Way 400W Push Dimmer Switch White | Dimmer Switches 400W | Screwfix.com) which control both the bulbs.
The second one is controlled by a 400w 1 Gangs 2 Way Dimmer BT (this one British General 1-Gang 2-Way 400W Push Dimmer Switch White | Dimmer Switches 400W | Screwfix.com) which control just the bulb in the dining room.
What's the reason the bulbs are flashing when the light is on? May it depends by the switch or by the bulbs?
Thanks.
I wonder if they are 60w incandesent equivalent aprox 10w leds ? not seen a 60w led household bulb yet!
Early leds were rated at 90 to 285 v so dimming was not possible as the electronics tried to keep the voltage/currant steady so they were either on or flashing on or off. the later dimmable type need special dimmers (as mentioned earlier) check with the lighting manufacturer or google trailing edge dimmer (most incandesent dimmers are leading edge and rarely work with leds)
Reply to Flashing dimmer LEDs, what's the reason? in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
