Flat roof mounting system | on ElectriciansForums
Discuss Flat roof mounting system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
solgen
Hi folks,
On flat roofs I've used proprietry mounting frames and usually had one row of panels spaced an appropriate distance apart from another.
On a smaller roof, the spacing of rows uses up a lot space, therefore, I was thinking of having one large 'sail' of 3x3 185W panels mounted onto a frame. The advantage is a larger system but at what cost? The method of fixing becomes non-standard (?) and ballast or fixing cost goes up! Has anyone one faced this situation and what have you done? Has anyone used Uni-strut to build a framework, or any other type structure.
I'd appreciate any comments, even from Mark W ;-)
Thank you
Solgen
I see what you are trying to achieve but I think you may come up against a lot of issues.
Planning, wind load, aesthetics etc.
I have not seen it done for flat roof but have seen two panels high by six as a tracker. ÂŁ40K job!
Have you seen the Ubbink Console system. Spacing between rows is the lowest I have found to date. I have been looking in to these for a ground mount we have in January so will be in a better position to advice on them after that. They are designed for flat roof installations, in fact that's what they are meant for!
Hi Solgen
You can build your own but be sure to design it with all factors mark explained above, we are designing a system for our unit roof, for maximum exposure for passing trade, this is only 5 large panels sitting tall, we are lucky we have steel fixers and welders in the next unit and my dad is a Technical designer, we are looking into costings and designs for other sizes soon as people are showing interest on our estate.
I have used the console mounts and they are OK but a bit cheap and nasty - you wouldn't want to put them were they can be seen.
For reducing spacing, look at solion. You lose some efficiency due to angle, but can make a good array on small areas or where weight might be a problem
Hi,
I've looked at most of the proprietry mounting systems: Ubbink, K2, Unirac, Schueco, (Solar centurys flat mount system - Looked like a good product with great instructions unfortunately, dealing with them was impossible).
Lowest fixed angle system I found was 10 degrees which makes row distance minimal, however, still a bit of a problem with large panels in portrait, and won't work with solion unfortunately for 2 reasons, the size of panels and the orientation.
Constructing bespoke frames for a small job will be to costly and eat into kW/ÂŁ revenue so I think I'll just have to offer a smaller system.
Incidently, has has anyone used solion? What surface did you put them on and did you use the silicon seal?
Thanks for comments so far.
Solarmounting system, solar racking system, solar bracket
Eachof our Enrichsun solar panel mounting bracket kits are made in the CN of thehighest-quality stainless steel. Our line of Enrichsun solar panelmounting bracket kits cover almost every type of solar panel installation, andare sized to securely mount all of our most popular GridMaxx solar panels.
Our Enrichsunsolar panel mounting systems include ground and roof tilt mounting bracket,side of pole solar mounts, top of pole solar panel mounts and RV flush and tiltmounting bracket kits.
Eachof our Enrichsun solar panel mounting bracket kits includes everything you needfor a complete installation, right out of the box – with no hassle, or annoyingtrips to the hardware store for additional parts and connectors.
Ifyou need assistance choosing the correct solar panel mounting system for yoursolar panel installation, please feel free to contact our team of solar expertstoday at: [email protected]
@solgen. We have used the solion mounting system a few times. The advantages are that it looks neat, low balast and no roof penertration. The disadvantage is that you can only fit Sharp or Romag 185wp modules in, a fairly major disadvantage, but we have had some customer who are ready to sacrifice some out put for the advantages. I have heard that Solion have a new system in development for 90% of panels.
We have fixed them to different surfaces with sealant but on some roofs you have to put down a barrier solution first.
The main problem I can see with the Ubbink consoles is the amount of balast required, I don't think many roof will take the weight without additonal structural work, the work great on the ground though.
Tom
Reply to Flat roof mounting system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
