C
coxy84
due to start some new build flats, do flats (3 of) need to have interlinking alarms or can they be treated as individual propertys?
Discuss flats fire alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
i havent got much to go off, iv got the a copy of the plans, there is going to be a 3 storey timber frame extension to an exsiting building with flats. the extension will comprise of 3x 2bed room flats 1 on each floor, there will be communal stairs/lannding that will be linked with the entrance hall of exsiting building. i belive the flats will be sold off once complete but maybe rented for a while.
i was thinking of treating each flat as a seperate dwelling with normal mains interlinked alarms, then a seperate system for the stairs/hall (communal area).
iv tried getting hold of my local fire officer but have had no luck.
Hi coxy84,
I would agree with audi95 and personally I would not suggest using a grade D LD1 system. If these were interlinked and were 'domestic smoke / heat alrms' I believe there could be a failure of the system due to unwanted alarms.
I think the advice of running it past building control and fitting a system such as a panel system to BS5839 part 1 would be better to think about. Certainly for the stairwells and communal areas.
You have highlighted it is timber framed which could be a higher risk factor in your risk assessment and also it is three storeys which I beleive pushes it towards what Audi95 has said.
Hope this helps,
Best wishes
Rex
i have look at the electricains guide to fire regs in the boss van only a quik flik through. i thought in hall ways u had to install a smoke not a heat?
Reply to flats fire alarms in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
