G
golfpaul
Im replacing two outside 100w halogens and re-routing the cables.
Would 1.0mm black flex with crimps be ok to use from fcu to lights?
Discuss Flex from FCU to outside lights. in the UK Electrical Forum area at ElectriciansForums.net
Im thinking more of 1.5mms t&e from cu to fco, then flex on to the lights.
The crimping i referred to was for the flex into the fcu.
Cheers.
Why? I have never used ferrels connecting a flex into a spur, just twist the cable in your fingers until tight and bend it over, what is this ferrel nonsence about then?Indeed he does.
I usually do it but then ive always got ferrules in my bag because we use km's of tri rated and beldon every monthWhy? I have never used ferrels connecting a flex into a spur, just twist the cable in your fingers until tight and bend it over, what is this ferrel nonsence about then?
Tri-rated I can understand.I usually do it but then ive always got ferrules in my bag because we use km's of tri rated and beldon every month
Well I am sorry I have offended you Jim.Nowt wrong with using ferrules, so i don't see the point of calling them nonsense.
Jim
Reply to Flex from FCU to outside lights. in the UK Electrical Forum area at ElectriciansForums.net
