B
brock
Dear all (I don't have access to the DIY section)
I have bought myself a new cooker ( Beko BD533A )
This cooker is pretty easy to install if I can find the right flex to install it with.
Now, the instruction manual says that it must be installed by a qualified electrician however i connected my last 5 cookers without any problems.
The instruction manual states a wire type that should be used (or equivalent) - The type is: H05VV-FG 3 x 4mm²
I went to B&Q to buy this flex and the man said that it's a heat resistant flex and they do not stock it. I checked with a few local stores and they also don't have this flex?
Can anyone recommend an equivalent length of flex?
Failing this I will need to call an electrician and pay money for him or her to effectively wire a plug.
Thanks for help, Brock.
Phone your local electrical wholesalers and ask for 3 core 4mm heat flex, they will sell it by the meter.
How important are the crimps on the ends? I didn't bother. I got the cable and installed it. If crimps are important I'll install it again with the crimps. (I didn't bother on any other cooker ive used)
Thanks from Brock.
crimps because fine strand flex is not meant to be screwed directly in a terminal. sometimes you can get away with it. other times you get a poor connection leading to overheating and/or arcing.
Oh.. I"ll take it back out and put crimps on this weekend. Cheers.
Why so many cookers?
I mostly have bought second hand cookers and cleaned them back to almost new. Infact this is only my second *new* cooker since 1999.
With fine stranded cable, it really depends on the type of terminal. A cage clamp, where the screw doesn't directly touch the cable, will be OK. A terminal where the screw bears directly on the strands would be better with a pin crimp or a bootlace ferrule.
A terminal where the wire gets clamped under the screw head will be better with a ring crimp although if there's a properly shaped clamp washer on top of the wire, I would say it's not required.
Flex to install a new electric cooker.
DIY Electrical Advice
brock,
dingledong,
