flex wiring rules | on ElectriciansForums
Discuss flex wiring rules in the UK Electrical Forum area at ElectriciansForums.net
M
markthespark77
Hi guys
whats the regulations in wiring in flex... I have a plug top ( Sure this is not allowed ) feeding a 3 m 1.0 flex, that goes under the floor boards, pops up in a cupboard then comes surface on the facing to a really old timeclock, before disappearing to an old water tank and back boiler . I have to learn more regulations, I was mostly doing new installs to the best standards, but now working for a letting agent and budgets are always tight , just want to be sure before I tell him ...I am under the impression flex is for 1 m or so..?
Thanks in advance
As far as I am aware as long as the diameter (I mean cross sectional area) of the cable exceeds the requirements then the only factor that matters is that the energy withstand time of the cable (i.e.70 degree or 90 degree etc) makes any difference in your calculations. Obviously that excludes mechanical protection.
My niceic inspector told me that you couldn't on the 16th edition but this changed on the 17th hence all the plug and play lighting now being used in commercial/retail. I had questioned it and he said it's ok as long as it's correctly sized/fused etc. i couldn't quote the reg no's though
Oh dear! Yet another example of an NICEIC inspector not knowing the regulations.
Flexible cables were permitted to be used under the 16th edition of the Wiring Regulation for fixed wiring in certain circumstances, where BS7671 521-01-04 applied.
In fact the regulations have become tighter (like most things) under the 17th edition, placing additional limitations on the use of flexible cable for fixed wiring, where BS7671:2008+A1:2011 521.9 group of regulations apply.
Some flex cables are obviously not meant for mains voltage, and some do not have the outer sheath required for fixed wiring. As you are talking about mains flex with an outer sheath, then it will be just as suitable as T&E if of the correct type and rating.
Reply to flex wiring rules in the UK Electrical Forum area at ElectriciansForums.net
K
Advice needed - questions before getting new bathroom fitted Hi all, hope this is okay to post. Just over a year ago, I took on my dad's old...
KamikazeBob
K
