Flexi armoured ??? | on ElectriciansForums
Discuss Flexi armoured ??? in the Australia area at ElectriciansForums.net
J
James Sutton
Hi All
Any thoughts on Flexi Armoured I think its called SY cable. Is it just used for interconnecting equipment or can it be used for anything else
Any thoughts please :confused::confused::confused:
Ok thanks for that got to run a supply for a Split unit air conditioning unit was going to use that as i think SWA would be to hard as it is a diffuicut run. The length of run will be around 30m max should be ok then and only pulling around 12A FLC
The Waterboard use it alot but as you mentioned its mostly short links from isolators and starters to apps, its a handy alternative to swa when flexibility and mech proctection is required but im sure the bs rating is important as the internal type really doesnt like direct sunlight.
have seen it installed with stuffer glands to maintain ip rating with the braid twisted sleeved and termed as an earth or drainwire but the correct slotted gland can be used similar to a swa gland to pick up the braid but i dont think they go up to e1w rating.
Reply to Flexi armoured ??? in the Australia area at ElectriciansForums.net
totally agree
This is an RSS feed of thread: Kitchen mixer tap 3 flexi hoses Content of the thread: Hi, I have just purchased a kitchen tap. I have extremely...
