flexi pipes not earth | on ElectriciansForums
Discuss flexi pipes not earth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
devlin maguire
Hi Again
If all supplementary bonding has been removed in a bathroom because of a new sutie and flexi tap connectors have been used so that now there is no visible copper pipes to bond to whats the solution
RCD protection is in place on all circuits
Mac
Reply to flexi pipes not earth in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If there's no main switch on the CU, then the RCD is doubling up as the main switch and everything is protected by it. If there is a main switch...
This is an RSS feed of thread: Hole in copper pipe, solder under floor, T coupling & protection Content of the thread: I was stupid enough not to...
