J
JANE61
Hi, We seem to have a problem with our downstairs ceiling lights. This happens regularly but not all the time. When turned on they flicker - sometimes they will then come on dull and then come brighter but sometimes they have to be turned off as the flickering gets worse. Other times you can hit the switch and they light perfectly. We have had an electrician out to them but he was baffled. He did say that when he tested the power it was wavering and not a constant reading? This problem seems to be worse at night. We have tried to isolate the problem by turning off other appliances but this has had no effect. We can't understand why it only happens sometimes and is only affecting the downstairs ceiling lights. Also (only sometimes) when you turn on the fluorescent light in the kitchen you can hear the light in the next room buzzing!:shocked3: It seems as though our power to these appliances is too low. Any help please???:wub:
