Flickering LED Spots Why? | on ElectriciansForums
Discuss Flickering LED Spots Why? in the Lighting Forum area at ElectriciansForums.net
Peterborough
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%.
We have installed 8 x ALUSSO LED Recessed Ceiling Lights, 7W 580LM LED Downlights Dimmable, 30MM Ultra Slim Round Black Spotlights
We are using this dimmer which states:
Input Voltage: 90V - 250V, AC 50/60Hz
• Load Power: 500W(INC), 300W(LED)
This is the dimmer:
CNBINGO Smart Dimmer Switch for LED, Work with Alexa, Google Assistant, Smart Life App, WiFi Touch Light Switch with Glass Panel, Backlight, Neutral Wire Required, 1-Way, 1-Gang, Black
https://amzn.eu/d/046zlvd
Any ideas where I have gone wrong?
Dimming led lamps is a minefield
compatibility between dimmers and lamps from different manufacturers is far from guaranteed.
I will always buy a solution from a reputable lighting supplier who will sell me lamps and dimmers designed and guaranteed to work together.
I tend to use Vpro dimmers etc .But recently have had good luck with Knightsbridge PINK dimmer with manual trimming on the back. (Lead edge type )
Find this LED dimming issue very frustrating. Had to replace back the old halogens because the Dimpull bathroom switch failed to support LEDs. Still looking for a solution or a replacement dimming bathroom pull switch.
Reply to Flickering LED Spots Why? in the Lighting Forum area at ElectriciansForums.net
