N
Neil the newbie
Hi there, i have a problem where I can't use my laptop on my 12v system even though my (probably terrible) maths says it should work fine.
Ill give you the specs first
290 w Solar Panel
PWM charge Controller
110 AH Leisure battery CCA 800
Laptop = Macbook pro, DC power supply is 11.6 - 16 v @ 5.6 A max (so the label says) the actual plug is fused with a 15A Fuse !!
What happens is when i plug my laptop in, the Led lights in my caravan go dim at first and then start flickering, getting more and more violent. the fuse box is fused with 8 amp fuses all the way except for where the main lead from the battery connects to it with a 16 A fuse
my laptop charges for a bit and then the charger just stops working.
A couple of times I've kept it on long enough and its actually pushed the fuse out and slightly melted it Suggesting the fuse is too big.
Changed it to a smaller one, but flickering continues.
My laptop showed fully charged this morning, however the lights were flickering very slightly without anything else plugged in. When i plugged the laptop in in wouldn't charge it at all.
yet sometimes, it will actually charge my laptop if i don't use it at the same time, and don't run any lights.
But there seems to be no rhyme nor reason as to when it will or won't charge, relating to the level of charge in the battery.
This battery is brand new as well so would be amazing if it was faulty.
If i try and use my 100 w inverter with my laptop it just overloads and reads not enough power, if i use my 150 w inverter the lights still flicker.
Ive gone through and all connections seem to be ok.
am i using the wrong wire or something, for the life of me i can't work it out.
if anyone here can help i would be so grateful this is doing my head in.
i think I've supplied all the info i have, but ill try and supply more if needed.
Many thanks
Neil.
290 w Solar Panel
Many thanks
Neil.
