Hi, called to a job where the "lights flicker"
Old rewieable fuse board with no RCD 5A light circuit which does flicker randomly every 20>30 seconds or so, no other real loads on .
Stripped the light circuit and found the first light on the loop in system , connected this back up and left the rest disconnected and still the same .
I then removed all other fuses to ensure no other circuit had an effect , still the same.
Finally I rechecked all connections / tightness and plugged a lamp in to a socket directly below the board , with nothing else connected and the lamp still flickered.
I feel it's a external influence but have no specialist test equipment to monitor , could any body throw some light ( non flickering ) on these types of problems?
Cheers
Cheers
