E
EIDR
Good Evening Guys,
Need to pick your brains....
Just finished 2nd fix for a local builder and I am having a nightmare with flickering 12v under cupboard lights.
The problems is in the kitchen, the lighting circuit and power circuits to the kitchen are seperate to the rest of the house other than the common consumer unit.
The lighting in the kitchen consists of 4 switched circuits.
1) 11 12v downlights - 50w each dimmed via a Richmond Lighting remote dimmer pack.
2) 3 12v downlights - 35w each dimmed via a Richmond Lighting Grid dimmer
3) 5 12v under cupboard lights 20w each dimmed via a Richmond Lighting Grid dimmer
4) 7 meters of LED strip fixed under counter tops switched from double pole grid switch.
All of the downlights are on individual transformers (MODE) and the under cupboard lights are 2 to each transformer (except the for one)
LED are Collingwood 24v drivers powering white LED's
The Under cupboard lights and LED are powered from the ring final via a FCU.
The problem is, the under cupboard lights flicker on the following occasions.
1) when the 11 downlights are dimmed
2) When the LED's are switched on (but not off)
3) When the kettle of other reasonable load is switched on.
4) When either the hob or oven are switched on (both on seperate circuits from each other and the ring final)
I have Looked at this for so long now that I have now got brain freeze!
Any ideas guys??
Appreciate the help.
Mark
Any ideas guys??
Mark
