Flint walls | on ElectriciansForums
Discuss Flint walls in the Australia area at ElectriciansForums.net
A
armbands0
Hi, I am after some advise as to drilling a hole in 2 foot thick, flint built, walls large enough for 25mm pvc conduit.
Any ideas, anyone successfully done it?
Cheers
[ElectriciansForums.net] Flint wallsThis is a small version, but it'll do the job.
Reply to Flint walls in the Australia area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
