Flood lights | on ElectriciansForums
Discuss Flood lights in the UK Electrical Forum area at ElectriciansForums.net
SparkyJoe
Hello, Im after a 500w equivalent LED flood light with 2 adjustable axis (like the pic) has anyone came across one? googles not proving much use
Cheers.
[ElectriciansForums.net] Flood lights
Cheers.
I too have been looking and have not found any 'multidirectional' LED flood lights at 30W or 50W! The largest I can find are the 16W (2x8W twin) from screwfix or TLC, plus the one Mike shows above.
It's difficult to give an 'equivalent' wattage LED to a 500W halogen as the specs seem to differ. Broadly speaking it seems that a 50W LED flood is similar in light output to a 500W halogen, although sometimes its a 70W. Probably best to look at the lumen output in the LED spec.
Typical LED floodlights seem to have a significantly wider illumination angle than traditional 150W / 500W halogen floods, so there's often less need to angle them. I've used these backets for some of the smaller LED floods (discarding one of the brackets):
Twin Halogen Flood Bracket
They appear to made of slightly thicker material than some other adjustable brackets.
Reply to Flood lights in the UK Electrical Forum area at ElectriciansForums.net
M
Cold Water Tank In Loft - Cause Of Flood Dispute? Having just moved into a property and discovering the central heating not functioning, after 3...
Mijacmad
M
