I would say that the CFLs are a little dimmer if you get the ones that fill the space of the flood, the ones that half fill the space are noticeably dimmer but OK for general lighting. The LED replacements are dimmer significantly, but the dedicated LED floodlights are about the same if you have the row of SMDs rather than the one single but cost about ÂŁ200.
If you are using the CFLs then you could fit two lights side by side at the same location, no more wires, similar look and no worries about overloading, unless replaced with 1000W again!
However the lamp should not be blowing that often so check for water in the fitting, loose seals, dirt /grease on the lamp as installed, good clean contacts in the fitting, secure wiring connections.
