Floodlight pir | on ElectriciansForums
Discuss Floodlight pir in the Australia area at ElectriciansForums.net
K
kduck
Is it possible to wire up a floodlight which has a pir on it, which would then turn on another outside light from that one pir on the floodlight.
Hi.
I forget the name of the manufacturer now I think it may be Spectra, but their fittings come with a 4th terminal to which can be connected an outgoing switched live to another fitting(s) up to a maximum of 1000W which are operated by the pir of the first floodlight.
Obviously you would need to keep an eye on the loading of the lighting circuit you are connecting on to.;)
Reply to Floodlight pir in the Australia area at ElectriciansForums.net
The existing wiring shows both brown wires into the same terminal. One should be in the terminal it is in now and the other in the terminal next...
That will work fine as long as the Pirs use relay switching, some don't.
