Floor convector heaters
Conservatory designer has specified a large and expensive building to include electric underfloor heating and some convection heaters at the doors, sunk in the floor just inside the door(s).
Originally these convection heaters were going to be 'wet' heaters but thats not possible, so looking for an electrical alternative.
The trench in front of each door is proposed to be the following lengths:
700mm
1400mm
2600mm
and the proposed heat output for each doorway is specified as:
0.46kW
0.94kW
1.72kW
Anyone know of product(s) that fullfil this requirement.
