SKY
Hi All
Just purchased 4 36W single florescent lights from local merchants.
Why do they only have a 3 way connector block inside them, I need to loop them together so need a 4 way, there is no room in my fittings to put in a 4 way and utilise the earth tag on the fitting.
Are you allowed to have a floating connection inside the lamp fitting with the use if a single extra choc?
SKY
SKY
