Big Man
- Joined
- Feb 28, 2009
- Messages
- 44
- Reaction score
- 5
Can someone assist me please?
Having never wired florescent lights before can you wire them using the loop in loop out method. I only ask as I'm having a problem with one of them am just off to buy a replacement starter for it to see if that's the problem. Feed comes off a socket spur through a 3a FCU to switch and then onto first florescent light that has a connector block in it and then onto the next (Only 2x 34W single lights). Wired in 1.5mm.
I just want to confirm this set up is okay and not causing problems and that it is just a bum light.
Your help is always appreciated
