flourescent starter keeps blowing , why | on ElectriciansForums
Discuss flourescent starter keeps blowing , why in the UK Electrical Forum area at ElectriciansForums.net
What info has it written on the side?
Cheap imports!
Faulty ballast!
Faulty lamp!
Bad contacts on endcaps may be causing the lamp to re-strike regularly which will prematurely burn out the starters...
loose wire in the control circuit
Pick from the above ...... to name a few
Cheap imports!
Faulty ballast!
Faulty lamp!
To quote David Cameron, calm down dear! lol
I'd want to know why the starters are failing. Can you give more info?
1 What type of ballast(s) is fitted, is it wirewound or is it electronic? Make and model number?
2 How many ballasts are there and how many tubes are there? What type are the tubes or what's their model number?
3 When the starters fail what happens? Have you dismantled a failed starter to check out the damage, if so what did you see?
4 How long do the starters last before they're kaput?
5 What is the make and model number of the starter?
Any chance of a photo of the inside wiring of the fitting?
It's a bit of a weird one because the starter isn't wired as part of the fitting it's only wired to the tube itself so I can't immediately think of a reason it would prematurely fail apart from those already mentioned.
Reply to flourescent starter keeps blowing , why in the UK Electrical Forum area at ElectriciansForums.net
Its important to remember that a plug top fuse is just a rewireable fuse that's convenient to change and shouldn't be confused with a HRC fuse...
