Chuck it in a skip and buy a non mft tester.
Done all of that, no point testing against known values because its not consistent. If I move the connectors it changesmost things with a mft giving iffy readings can be down to one of 3 things, batteries, the leads/contacts or the fuse inside.
Not sure about meggers and whether you can access the fuse to check it is seated tightly. but with others that can help.
change your batteries, clean the leads and test against known values.
Also check how you null your leads out.
a hammer will do nicely .Try Zeroing the leads first, unless you do that the readings will not stabilise
My separates are a Robin loop tester and insulation tester and a Megger rcd tester, no problems whatsoever. Colleagues use mfts and they seem to spend all day faffing with them.westward 10 im seriously considering that lol. do you use separates? if so which ones, how do you find them vs a mft
Can you null it as per @MDJ?Done all of that, no point testing against known values because its not consistent. If I move the connectors it changes
