M
musicmaster050
hi i have just bought a 1651 from ebay but am not 100% sure that it works iam new to testing and plan on taking the c & g fundamental corse soon for testing
problem is i have been testing sum circuits that i have rigged up in my garage to get me used to the meter problem is when i set the meter to continuity on a ring main i get these reader between
line 0.21
neutral 0.23
cpu 0.27
after having a look at the osg all seem well then it says put the line of the outgoing ring main onto the neutral return and test at the sockets so i plugged in the socket lead and when i press the test button the screen just stays on 2000m
just wondering if you could help me out as am not sure if the meter is faulty
also seem to be having problems with ir test but i have never used one of these so i could just be doing it wrong any advice of help would be great thanx from mike
you have to start sumwhere
anyone no of any dvd from this meter which take you though step by step
line 0.21
neutral 0.23
cpu 0.27
