Discuss Fluke 1652 High readings. in the Electrical Tools and Products area at ElectriciansForums.net
Just purchased a second hand fluke 1652 mulifunctional tester. I am getting very high readings. Resistance between my leads is 0.58 and EFLI readings above what I would expect. I have had the tester calibrated. Swapped the leads around etc.
Has any body had the same problems with these testers?
This is my first post so hello cyber sparky world.
I also have a secondhand 1652, it is only 18 months old, i was getting allsorts of weird readings, and lots of fault messages on it. I dont want to try and sound a t**t but have you read the instructions properly? I didnt, but once i did i started getting the proper results. It was a case of i want to play with my new toys and i'll read the instructions later.
Cheers..........Howard
Reply to Fluke 1652 High readings. in the Electrical Tools and Products area at ElectriciansForums.net
These Official Forum Sponsors May Provide Discounts to Regular Forum Members - If you would like to sponsor us then...
Having some issues with my companys fluke 1662/1663 tester.
Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
I've discussed this with the OP directly as we are friends, but for anyone searching in the future, the service manual suggests that this...
