Mark.W
Hi
Does anyone know if the Fluke 1652 is 17th ed compliant?
Regards
Mark
Regards
Mark
Discuss Fluke 1652 in the Electrical Tools and Products area at ElectriciansForums.net
Fluke 1650B Series Multifunction Testers test to BS7671, 17th Edition Wiring RegulationsThere is no such thing as a 17th edition tester.
Surely its the tests you do and not the tester that make it 17th compliant?
The new 1650B Series builds on the rugged reputation of the earlier 1650 Series, only it’s re-designed to meet your need for more productive test tools.
This new series contain the following new features:
These are the differences between yours and the 1650B series
- Fast high current loop test
- Variable RCD current mode for customized settings
- PASS/FAIL indication for RCD tests
- FLUKE-1651 with 250 V insulation test voltage (250 V, 500 V and 1000 V)
- Select voltage measurement between L-N, L-PE and N-PE
- Zero adapter for easy test lead compensation, available as new accessory and also included with standard scope of supply
Reply to Fluke 1652 in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
