Spoon242
I used my fluke for the first time today practicing on a test board I built up for 2391 paractical exam.
I went through all the tests and got to the live tests.
First test was supply polarity and I am getting a reversed L-N reading on the display. L-E read fine, N-E also reads fine. Confused, I can see it is all wired correctly, but have to do the test for the exam.
The test board is on a plug, however, by testing the circuit supplying the plug and with the plug removed, it also reads reversed.
It reads reversed on two other ring finals at other circuit around the building.
Hmmm, confused.
Could it be that my new meter is not working correctly?
The display shows three dots across the top with L-N using two and an linked arrow between the two. I read the manual and it says reversed polarity.
Hmmm, confused.
