fluke 1654b | on ElectriciansForums
Discuss fluke 1654b in the UK Electrical Forum area at ElectriciansForums.net
C
Cookiebadboy08
I have recently bought a fluke 1654b but when I do r1r2 it the continuity varies badly is this normal for flukes
Any help would be appreciated im use to metrel testers
Its usually the leads I had problems and they kept sending me new ones. But the same problem kept occurring I now use the meggar unfused leads which work well and are reasonably priced.
What do you mean varies badly, does it not settle on a set result, instead fluctuating up and down constantly while the leads are connected?
Is it calibrated?
Have you shorted the leads?
Have you compared the results alongside another tester/ against a known figure?
Is it calibrated?
also is it your first tester?
Could be your not applying equal pressure when testing
I have the same tester , you need good batteries , and the leads are not good , I find if you zero the leads that the readings are wrong sometimes due to faulty leads , I now use a different make leads and no problems , its the same with the 1652 as well ,,
I have just bought from test for less and calabirated as well not tested with a different tester no but I put crocodile clips on and still varies a bit but it will go from 0.07 to 1.27 ohms in a flash it will not settle at all its really bugging me
Cheers guys
Cheers guys
Thats the same problem I have had ,, its always the leads though , even with the Croc clips removed ,,,
How can thus be they are brand new I am fumming for 700 pound well annoyed and not impressed at all it was so bad I tested some dp isolaters and r1 r2 was higher than the zs
Jesus back to the supplier then would it be easier to change tester
I have a 1654B and no issues, it has once given a weird reading but replugged the leads and all was fine. Does anyone know what the actual issue is with the leads?
Not sure , I haven't bothered using them since , they look all right , I use another make now and all is o/k , I did try another new set of fluke leads but they did the same after a while,, I have always had Robin and now Fluke since the 1980s , never had this problem before , have had the 1652 for 4 years now , and the 1654b for 2 years ..
Reply to fluke 1654b in the UK Electrical Forum area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
KT66EVA (KT66DL & KEWEVA) - ÂŁ1073.60 + VAT if you shop about as a combo
