Fluke 289 for everyday use? | on ElectriciansForums
Discuss Fluke 289 for everyday use? in the UK Electrical Forum area at ElectriciansForums.net
Manchester, UK
Evening, considering buying a Fluke 289.
Is it too big and heavy for general multimeter use?
Interested to hear from people that use one, thanks.
I recall the OP was working in fault finding on control panels, as opposed to more traditional electrician disciplines, as there are a couple of other recent threads started on the same/similar topics.
For an electrician's everyday meter to grab for quick tasks, I guess most would say the 289 is too large and complex, akin to using Excel when a pocket calculator will give you the same answer in a fraction of the time.
There is a good review of the 289 below which I've linked to (Mods, I hope that is OK to link to, I'm still quite new here so please delete if against the rules)
Annoyed with the Fluke 289 - Page 1 - https://www.eevblog.com/forum/testgear/annoyed-with-the-fluke-289/
Funny you should mention that
I bought a fluke 287 this week
It is a heavy big thing, I am actually afraid of dropping it, it is good for data logging.
I also have a 115 and a 179. I love the 179
Interesting, thanks!
Well I bought one in the end and I’ve been using it for a couple of months now.
It’s very good and apart from my Fluke T130 voltage detector, it’s the only meter I use now.
It takes a couple of seconds to ‘boot up’ from some of I reviews I’d read I thought it would be a lot longer!
The ability to show DC and AC voltages saves a lot of time fault finding.
Showing current, max, avg & min readings on the same page is very useful.
Battery life is good considering what it can do.
The first time I used it I had to confirm that an output from a machine was giving out a continuous voltage of between -25 to +25v to prove that a input sensor and the controller were working fine and that the fault of a motor sometimes stopping working, was elsewhere. I just connected the 289 and left it logging for a few hours. Looking at the graph it produced, there was no loss of voltage during the logging. Using the min/max over a period of time with a different meter wouldn’t have worked as it would have shown max as +25 and min as -25.
One problem is that it only takes readings every 0.25 seconds, so if you are measuring something that for example pulses every 1.3 seconds then it can miss the peak and show an irregular peak voltage.
[ElectriciansForums.net] Fluke 289 for everyday use?
too complex for me. this is my level:
the needle moves - there's some lekky about.
Reply to Fluke 289 for everyday use? in the UK Electrical Forum area at ElectriciansForums.net
I use this one, copy this into a search engine: 200EP Tone Generator Kit High Accuracy Cable Toner Detector Finder Tester with Inductive...
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
