W
weep
as above, has anyone have any experience of this using touch dim switching ?
how does it work 2 wayed using retractable switches.
i was under the impression i could have a touch dim dimmer one end and a normal 2 way switch the other end, however, the lights are doing funny things, ie dimming up when normal 2 way switch is pressed and not turning off from that switch also.
Is there some kind of slave unit needed here ?.
thanks in advance.
thanks in advance.
