Steve781
Hi
firstly I would have posted in the diy forum but I don't have permission. Hopefully someone can advise me though.
We have a fluorescent ceiling pendant light in a recently rewired kitchen. After a few weeks there was a blue spark and bang and the light stopped working. Switching the power on resulted in a loud buzzing noise. Once the light came down we could see brown markings around the electronic ballast.
Our builder said maybe water had got in from the bathroom above. This didn't really make sense but we got an identical replacement. They installed it and it has been up about a day and barely used and its blown again. Same thing happening and believe the ballast has blown.
Any ideas on what would cause this other than a faulty unit. It's a Phillips light fitting and I wouldn't expect they are both defective.
the only thing I noticed is that some foam packaging had been left on the tube both times. I cannot imagine this caused a problem with the ballast though. The tube appears to be completely intact.
Obviously I want to avoid wasting yet more money on another fitting. The builder dis his own wiring where possible and it was all checked and signed off by an electrician. I am thinking of getting a different electrician to come and fault find but I don't expect they will find anything. Any advice?
There are other lights on the same circuit (led spots) but these are fine. Both times the ballast has blown has been at the point of switch on.
Thanks for for any advice.
Steve
Steve
