fluorescent ballast problem. | on ElectriciansForums
Discuss fluorescent ballast problem. in the Australia area at ElectriciansForums.net
telectrix
Mentor
Nearly Esteemed
cheshire/staffordshire
client has about 24 1200 x 600 recessed fittings in suspended ceiling ( shop ). problem is 6 are not working. it's not the tubes, there are no starters, so it's got to be the ballast units. ordered from local supplier 3 weeks ago. today they say they can't get them. each fitting has only one ballast to run the 4 tubes . my problem is ... do i try and obtain ballasts or would it be more economical to replace the complete fitting ( ÂŁ41 + VAT from TLC.) might just be the ballast cost is close to the cost of a new fitting.
i would want an exact replacement. don't want to spend loads of time working out the connections and having to drill fixing holes
I worked for a company doing retail lighting maintenance for a few month, the main thing we did was change ballast and lamps. I had never ever changed a ballast until I started working for them. I thought surely it is cheaper to change the whole fitting but when some of the fittings are that old and you can't replace it then changing the ballast is the only option. Some cdm ones are about 150 quid and sometimes the fitting is cheaper or sometimes it could be a 300 quid light fitting. I used to call the job ballast bashing!
Sent from my HTC Desire using Tapatalk
you sure there isnt a fault telectrix, have you checked continuity and stuff;)
come off it. i=p/u, there's 230v at the fitting. there's 4 tubes, 1 ballast, and a bit of string joining everything together. it ain't the tubes, it ain't the string, so there you go.
Some ballasts have a safety feature that 'trips' supposedly to reduce the risk of high temperatures or fire when tubes reach end of life and don't ignite cleanly. This can make the ballast appear to be faulty. Often they reset automatically when tubes are replaced but one or two makes have manual reset methods. I think it was one of the BAG models (DALI type) where you had to short two contacts on the back side of the ballast and there was another one where you had to cycle the light switch fairly quickly twice or three times to manually reset it. Best thing to do is check online for a pdf spec sheet for the particular ballast you're dealing with.
Reply to fluorescent ballast problem. in the Australia area at ElectriciansForums.net
