Fluorescent hum in bathroom light | on ElectriciansForums
Discuss Fluorescent hum in bathroom light in the Lighting Forum area at ElectriciansForums.net
Reading
  • [ElectriciansForums.net] Fluorescent hum in bathroom light
Just put my ear up against the fitting and the hum wasn't coming from there. However, I can hear it clearly if I put my ear to the wall.
If it’s happening when the lamp is off, it may not be the lamp at all.
Is it constant, or does it happen from when the switch is turned off and slowly disappates?
What else electrical is in the bathroom? Shaver points can hum as there’s a transformer inside them, same with heated mirrors (anti fog)
It could also be a loose connection in the switch causing high frequency arcing.
Try and pinpoint where the sound is coming from.
If it’s in the wall, it may be something outside the bathroom
Could it be an extractor fan with a run on timer?
Reply to Fluorescent hum in bathroom light in the Lighting Forum area at ElectriciansForums.net
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
To be honest Markelect, You have had a good 25 years trouble free, I wouldn't waste any more time and effort and just go for a full replacement on...
