Fluorescent lamp Ballast testing | on ElectriciansForums
Discuss Fluorescent lamp Ballast testing in the UK Electrical Forum area at ElectriciansForums.net
chippenham
Hi All
new here looking for your advice. i have a fluorescent tube fitted in my kitchen which is no longer working. Changed bulb checked trips etc, all fine. only thing I can think of is the ballast has failed. I do have a multimeter but wanted to ask how I go about testing the ballast using the resistance feature on the meter. Should there be an open circuit or if I get a low reading is that a sign of a bad a ballast. also which wires do I check between?
I am certain this is the fault but I don't want to go buy a new one if it isn't, also. knowledge is key!
thanks in advance
Dan
Hi All
thanks in advance
Dan
How to Check If the Ballast Is Bad in Fluorescent Lighting - http://homeguides.sfgate.com/check-ballast-bad-fluorescent-lighting-39399.html
I would personally. No messing with ballasts, starters, tubes etc, better light ouytput, lower running costs. You would need to decide on the sort of colour you want want (warm, cold, etc.)
Reply to Fluorescent lamp Ballast testing in the UK Electrical Forum area at ElectriciansForums.net
Thanks very much for your kind suggestion. Really - it is most likely to do with a very flimsy cold-cathode-start inverter, as the tubes barely...
You really need an inductance or LCR meter or a ring tester which are expensive to buy but you can make your own ring tester if you want a project...
