Hi, any advice please?
Got asked a question today that I couldn't figure out so any help would be appreciated. Kitchen fluorescent tube had been in for about 5 years or so and all well, then started flickering like a strobe. Works fine on initial start up but after an hour or 2 starts this annoying flicker motion... the occupants then replaced the tube with similar rating but still after 2 hrs or so flicker came on. when this happened they have to turn the switch off and turn back on again to stop the flicker for another few hours.
then they thought it was the light fitting so decided to change the whole light for another fluorescent light and same thing happens again? All is well on start up and for a few hours until flicker starts?
I tested the circuit and all is well, Ir a bit low but expected for age of wiring. A little baffled as all is fine when turned on but seems to flicker only after a while. Also happened to 2 lights so thought it couldn't be the fittings. Tubes came with fittings so I thought couldn't be that either? wiring all ok also. No noticeable buzzing noise either. Any advice please?
I think the light is on the end of the radial so could it be that?
