M
Mike Blair
ok. so my TV is old and has a small hissing sound. when i turn a fluorescent light on it makes the hissing sound slightly louder. whats the reason to this?
Discuss fluorescent light interfering with tv? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The ballast will generate RF noise new ballasts are high frequency and they should have a filter to stop this.
try an inline choke/ferite core on the mains lead of your tv (they click over the cable no wiring req) just select the size you need for the cable
an example on ebay 2X 11mm FERRITE CORE - FERROUS RING CHOKE CLIP ON NOISE FILTER EMI & RFI | eBay
carnt be certain it will work and if you arnt in a hurry order from china on ebay very cheap. Hope this helps
Reply to fluorescent light interfering with tv? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
