Hello guys, I went and viewed a job today. The shop has 32 double battens divided into 5 15 amp breakers. The wiring is a nightmare. With the switches arcing and burning smell of the switches. Isolated switch with problem as that somehow is interconnected with another 4 mcb's. Just wanted to know if I calculate the lightings the same as any other. If im correct 15 amp mcb's are too high if a load. Can I reduce to 6 amp.
64 tubes
6400/230
27.8amps/5
5.56amps
So a 6 amp breaker should be sufficient if im correct. Please advise.
Gonna probably rewire the job. Hence need the advice. Thank you.
64 tubes
6400/230
27.8amps/5
5.56amps
