Spearmint
So I was wiring my first set of fluorescent lights today (Ansell, 49W per strip, double units so 98W per fixture) and wired in parallel (switch wire to the first set of doubles then to the next fixture, four strips in total) so the lines/neutrals/CPCs were connected in the first fixture then to the next one. Turned them on on and the first fixture came on fine but the second only lit on the ends of the strips. Wiggled the strips but nothing changed and the annoying thing was I didn't have time to try and figure out what was wrong.
Circuit is wired (temporarily) into a plug for testing so running from an existing ring main with five amp fuse. Have I missed something obvious here? It's a shame that I won't be back there for a few days to check for any loose connections etc. despite the strips "trying" to turn on.
